Brief Description: Updrill right main spar components
Updrilled components on the right end of the main spar. Deburred and primed components.
I had to notch W17-07 slightly to clear the release pin (both L&Rsides). It might not have been an issue because it appears the taper on the pin is about all that protrudes through the spar when locked.
The taper on the shank of the pin hits the guide block preventing the pin from making fulI engagement in the rear spar plate. I counterbored block W16-02 so the pin would engage the spar more completely with the taper fully exposed when locked.
Attached a 12vdc-5vdc converter to the back of the AirGizmo mount for the AV8OR. Replaced my homemade power connector with a commercial right angle connector I found on-line. Wired up power and grounds and the power supply works ok, powering and charging the AV8OR.
